I try unsuccessfully to play music into a NAD 3050 LE streaming from a MacBook Pro, when I try to do as instructed and disable the option to send RAW PCM stream, as soon as I chose the NAD as output device Audirvana shows me " Device does not accept any uncompressed PCM streams"
NAD doesn’t support UPnP nor Chromecast, so the only way to play to it is using digital inputs. You can‘t stream directly to it.
