I stream with Audirvana to Devialet Phantoms and want to use a Chord Qutest as a wireless DAC. What devices as either standalone players or DLNA/UPNP only to USB work with Audirvana?
Steaming to Bluesound node 2i doesn’t work, but something like that with High Res capability would be awsome.
It depend a bit on the budget and/or size constraints. The cheapest is to use Chromecast Audio dongle via TOSLINK.
Or if you’re willing to spend a bit more…
Stream Box S2 Ultra
https://www.project-audio.com/en/product/stream-box-s2-ultra/
Now that looks like the sort or thing I need. Thanks
I’m curious how you connect the Chord DAC to the Phantoms?
The phantoms and dialog work as a standalone system with Audirvana. I plan to use the chord in a second system doing away with the USB tether.
Aha, now it makes more sense.
