Different Volume Levels On Different Computers
Hi,
I have Audirvana installed on my two Macs, an iMac and a Macbook Air. Using the remote app on my iPad I compared using the two of them with exactly the same settings, retrieving the same tracks from my network NAS and playing through my network streamer to my RME ADI-2.
I was very surprised when I heard a very apparent volume difference between them. When running Audirvana on the iMac it was a lot louder than running it on the Macbook Air?
I have checked all the settings and they are exactly the same, volume is 100% on both and there is no volume levelling engaged.
Any ideas? Am I missing something obvious here?
Hello @ctrlm,
Can you send me a copy of the ā€œDebug Infoā€ for your two devices? You can get it in Audirvana Settings>General>Debug Info
Hi Damien,
Here is the info:
Macbook Air
macOS 10.14.6 with 4096MB RAM
Registered to Mark Glendenning
	AU plugin #0: Effect - ToneBoosters TB_Equalizer_v4 ()
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
AUTO: /Volumes/Music/AIFF Music
Library database path: /Users/MacbookAir/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1024MB
Built-in Output
Model UID:AppleHDA:126
UID:AppleHDAEngineOutput:1B,0,1,1:0
Active Sample Rate: 48kHz
ID 0x2e Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:126 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x2f 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:126 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 Digione UID: uuid:97ebcfad-1a7a-3bbe-ad39-b827eb1d8645 Location: http://192.168.1.9:49152/description.xml
iMac
macOS 10.15.7 with 24576MB RAM
	AU plugin #1: None
	AU plugin #2: None
	AU plugin #3: None
Library database path: /Users/markglendenning/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 21504MB
FOCAL ARCHE Audio 2.0
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0
UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14300000:1
Sample rate switching latency: 1s
ID 0x3b FOCAL ARCHE Audio 2.0 Manufacturer:FOCAL
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0 UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14300000:1
Stream ID 0x3c 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x3b FOCAL ARCHE Audio 2.0 Manufacturer: FOCAL Model UID: FOCAL ARCHE Audio 2.0:152A:87A0 UID: AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14300000:1
If you don’t use the ToneBooster Equalizer, does the volume is the same or not?
Hi Damien,
that’s a good point, I will try it later and let you know.
I appreciate your support, even though it’s not exactly a major issue.
Cheers
Mark
