Hi,
I use Audirvanva in my office for music, amp/speaker instead of headphones.
Because of the limited options for placing the speakers I opted for the DiracLiveProcessor.
All in all quite happy.
In real time mode Audirvana is snappy, without that it can take up to seconds to change tracks.
When I enable the EXPERIMENTAL Audio Units MacOs hosting api the snappiness returns but sounds very bass heavy.
A known issue or related to my setup?
Thanks in advance,
Bob
Audirvana Studio 1.12.0 (11200)
macOS Version 12.3 (Build 21E230) with 16GB physical RAM
Connected account of : Bob Tito
Effects plugins ACTIVE in realtime mode with legacy macOS API
AU plugin #0: Effect - Dirac Research DiracLiveProcessor ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Phase minimum phase
Replay Gain: by track
AUTO: /Users/bobtito/Music/Music/Media/Music
Library database path: /Users/bobtito/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50822
Max. memory for audio buffers: 4106MB
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:2100000:1
ID 0x3b SMSL USB AUDIO
Manufacturer: SMSL
Model Name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:2100000:1
Stream ID 0x3c 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x3b SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:2100000:1 Model Name: SMSL USB AUDIO
Device #1: ID 0x2f Mac mini luidsprekers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini luidsprekers
Device #2: ID 0x35 Dirac Virtual Audio Device Manufacturer: Dirac Research AB Model UID: com.dirac.vad_ModelUID UID: com.dirac.vad_UID Model Name: Dirac Research AB Dirac Virtual Audio Device
