Audirvana Studio 2.2.3 (20203)
macOS Version 13.2 (Build 22D49) with 8GB physical RAM
Connected account of : Terry Clotiaux
AU plugin #0: Effect - Dirac Research DiracLiveProcessor ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX custom frequencies
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: /Volumes/Music Server 1/Music Server 16_v2
iTunes/Music library synchronization: last synchronized on Thu Feb 2 18:19:07 2023
Library database path: /Users/MR_MUSIC/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49466
Max. memory for audio buffers: 5998MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
PS AUDIO PS AUDIOUSB 2.0 AUDIO OUT
Model UID:PS AudioUSB Audio 2.0:2616:0102
UID:AppleUSBAudioEngine:PS Audio:PS AudioUSB Audio 2.0:0000:1
Selected device:PS AudioUSB 2.0 Audio Out
Manufacturer: PS Audio
Model name: PS AudioUSB 2.0 Audio Out
Model UID: PS AudioUSB Audio 2.0:2616:0102
UID: AppleUSBAudioEngine:PS Audio:PS AudioUSB Audio 2.0:0000:1
USB Vendor ID: 0x2616
USB Product ID: 0x0102
ID 0x32
Stream ID 0x33 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 3
Device #0: ID 0x32 PS AudioUSB 2.0 Audio Out
Device #1: ID 0x55 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #2: ID 0x3c Dirac Virtual Audio Device
Manufacturer: Dirac Research AB
Model UID: com.dirac.vad_ModelUID
UID: com.dirac.vad_UID
Model name: Dirac Research AB Dirac Virtual Audio Device
