Are there any news regarding the dirac installation?
Another way to skin this cat is to use free REW to measure and create room correction EQ filters that can then be used by many vst plugin convolution engines to apply room correction…
Hi @rainer1,
What do you mean by that? You are talking about the possibility to change the settings of the plugin while playing a track over UPNP?
