Hello and happy new year 2022,
I’m looking for a solution to avoid the dirac plugin VST to start/stop randomly.
When I freshly start the software it works properly even during short sweep file play to test with REW BUT it stops randomly after X music.
The ONLY solution is to restart audirvana. This is happening more often with V3.5.2 than with studio that I’m testing before to adopt it.
I’m using WINDOWS 10 PRO/AUDIRVANA STUDIO or V3.5.2/DIRAC VST PLUGIN/UPNP LINK/ LUMIN D2.
