When I set studio streaming to Direct Mode and stream to Dirac software and then from Dirac to DAC the Dirac starts to act funny with bad sound after a while.
When I do the same set up but with no Direct Mode its seams like Dirac has no issues.
Can it be that it is not working and shall not work to use Direct Mode if you stream to a software like Dirac?
Thanks. I have not checked if I hear a difference but when in Direct mode my DIRAC software that I am streaming against works for a while and then the sound gets distorted. But now I have cancelled Direct Mode and it seems to work. So my question is does Direct Mode make it impossible to stream to an audio software in the MAC. Or can you only in Direct Mode stream out of the MAC.
I use DIRAC stand alone since I have this since 7 or 8 years. I have not tried the VST plug in version since I have High Sierra and it looks like the VST plug in only works with later IOS. My DIRAC has max 24/192 and so does my DAC so i have no upsample needs beyond that. I actually do not upsample at all.
