I’m new to Audirvana since two months, I use it on my MacBook Pro late 2013. I read that Apple has blocked the Direct Mode option on Big Sur, but is there a significant difference in sound quality if you have the direct mode enabled?
Direct mode doesn’t work since macos Sierra… Audirvana still sound great since
