Debug
Audirvana Studio 1.12.2 (11202)
macOS 12.2.1 with 32GB physical RAM
Connected account of : Eugen B
Per track: OFF
AUTO: /Users/dirt/Music/Local Library
Library database path: /Users/dirt/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52604
Max. memory for audio buffers: 16022MB
TOPPING D70S MQA
Model UID:D70s MQA:152A:8750
UID:AppleUSBAudioEngine:Topping:D70s MQA:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 384kHz
Active Sample Rate: 384kHz
Hog Mode is on
ID 0x5f D70s MQA
Manufacturer: Topping
Model Name: Topping D70s MQA
Model UID: D70s MQA:152A:8750
UID: AppleUSBAudioEngine:Topping:D70s MQA:14100000:1
Audio buffer frame size : 231 to 4096 frames
MQA Decoder device
Stream ID 0x60 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x40 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x5f D70s MQA Manufacturer: Topping Model UID: D70s MQA:152A:8750 UID: AppleUSBAudioEngine:Topping:D70s MQA:14100000:1 Model Name: Topping D70s MQA
Device #2: ID 0x2a Sonarworks Systemwide Manufacturer: SIA Sonarworks Model UID: com_sonarworks_driver_SonarworksDevice:Sonarworks UID: SonarworksEngine:0 Model Name: SIA Sonarworks Sonarworks Systemwide
UPnP devices found : 1
Device #0: ID 0x0 Botic7_192.168.88.218 UID: uuid:08e3d638-180f-5018-9536-38d26955142e Location: http://192.168.88.218:49152/uuid-08e3d638-180f-5018-9536-38d26955142e/description.xml
