Hello,
Playing from Qobuz Studio in Audirvana 3.5.44 with Windows 10:
Someone knows the reason?
Hello,
Again,
audirvana shows on right your dac max bitdeph, yours we see is 24. Mine is always 32/44 but what hear is 16/44, same for you if you don’t upsampled in audirvana
Damien, the “Debug Info”, thanks
Audirvana 3.5.44
Sync list: 3 folders
AUTO: C:\Users\musica\Desktop\Focal tools CD
AUTO: D:\Musica
AUTO: D:\Revisar
Library database path: C:\Users\musica\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 2530MB
Local Audio Engine:WASAPI
Altavoces (Benchmark DAC2 USB Audio 2.0)
Model UID:Altavoces (Benchmark DAC2 USB Audio 2.0)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b84c5474-0904-41fa-9363-6ab16ea7770c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 24bits Integer, 8 bytes per frame 44.1kHz
Altavoces (Benchmark DAC2 USB Audio 2.0) Manufacturer:
Model UID:Altavoces (Benchmark DAC2 USB Audio 2.0) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b84c5474-0904-41fa-9363-6ab16ea7770c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
Device #0: Altavoces (Benchmark DAC2 USB Audio 2.0) Manufacturer: Model UID: Altavoces (Benchmark DAC2 USB Audio 2.0) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b84c5474-0904-41fa-9363-6ab16ea7770c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
