Windows 11>Audirvana Studio 1.10.2>Chord Mojo.
When the Mojo for any reason switches off, Audirvana Studio crashes, refuses to close and when windows force-closes it, it does not open again.
Only when I restart windows it gets back to normal.
Any ideas?
Hello @Loop,
Can you send us your audirvana.log and audirvana.dmp file?
to show AppData folder:
Thanx for the reply.
Which email should I send it to?
Just did.
Basically same on my Mac mini, don’t have to restart computer but if I turn off Oppo205 before exiting Audirvāna it will hang spinning beach ball of death then crash after forced exit. Creates crash report to Apple.
