Hello all,
I’m new to Audirnava and just installed it on a Mac Mini Late 2014 with 4 Gb RAM and 256 Gb HD.
I haver a ADL GT40 DAC attached via USB. The sound via the DAC is completely distorted.
I tried all settings, but luck.
As mentioned in another thread, I tried other USB ports, no luck.
I tried another program (Vox) to play my hi-res FLAC files (24bit / 96 Khz), but the same problem.
It sounds fine on the local output, but not via the Usb / DAC.
The strange thing is that I have another Mac Mini late 2012 with 10 Gb RAM en 512 Gb SSD drive and everything works fine. This one uses bluetooth keyboard and mouse, so I switch these to to the other Mac to see whether this was the culprit. Unfortunately not.
After testing these different option, I come to the following conclusion:
- The USB ports on the Late 2014 Mac are all faulty (?) or
- The Memory and disk speed on the Late 2014 Mac are not up to par to play any file ?
Does/Did anyone experienced the same problem ? I don’t think Audirvana is the problem.
Cheers,
Peter
