I am hearing frequent distortion on multiple tracks. It is not present when streaming directly from Tidal, only when running Audirvana. I’ve switched headphones and DAC’s but the noise is still there. It is NOT present for any locally stored music files. Ideas?
Hello @snip2062,
macOS 10.13.6 with 16384MB RAM
Registered to Stephen Power
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 2 folders
AUTO: /Volumes/Main Drive/Hi Rez Music
AUTO: /Volumes/Main Drive/Users/stevepower/Music/iTunes/iTunes Media
Library database path: /Volumes/Main Drive/Users/stevepower/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
HRA-Streaming: Login failed
Schiit USB Multibit
Model UID:Schiit USB Multibit:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Multibit:fd130000:1
Active Sample Rate: 48kHz
ID 0x40 Schiit USB Multibit Manufacturer:Schiit Audio
Model UID:Schiit USB Multibit:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Multibit:fd131000:1
Stream ID 0x41 2 channels starting at 1
24 virtual formats:
36 physical formats
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:39 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x40 Schiit USB Multibit Manufacturer: Schiit Audio Model UID: Schiit USB Multibit:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit USB Multibit:fd131000:1
That seems to have worked! Buy, why ?
You activated the Effect - Apple AUGraphicEQ and you probably changed the settings of the effect, to be sure the issue is from this you should configure it in Audirvana and set it as default like this (click on Flatten EQ):
I did as you have suggested and no change - it sounds as it should. Thanks.
