Hello @Antoine
Please find the debug info:
macOS 10.14.6 with 4096MB RAM
Registered to Gabriel Caliz
AUTO: /Volumes/My Book/SACD/New Audir
Library database path: /Users/gabo/Downloads/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 722MB
McIntosh-HD HS USB Audio
Model UID:McIntosh-HD HS USB Audio:2AFD:0005
UID:AppleUSBAudioEngine:McIntosh:C52:14100000:2
ID 0x6c HDMI Manufacturer:Apple Inc.
Model UID:AppleHDA:88 UID:AppleHDAEngineOutputDP:1B,3,1,2:0:{A320-0088-00000001}
3 available sample rates up to 48000Hz
32000
Stream ID 0x6d 2 channels starting at 1
3 virtual formats:
9 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x36 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x6c HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{A320-0088-00000001}
UPnP devices found : 1
Device #0: ID 0x0 Pioneer BDP UID: uuid:140479c0-58f3-1cef-84bf-745e1c86d1e9 Location: http://192.168.0.143:2870/dmr_CUXE.xml
Thank you!
Gabriel
