Hi, I have Audirvana and it works fantastic with my HEOS AMP and my Sonore Transport/microRendu. DSD, Tidal, all of it works all the time. I wanted to put a cheap network receiver in the garage to use with Audirvana. I see most with DLNA and only a few that say UPnP. Which one do I need? Wiki says DLNA works with UPnP underneath it. But does that mean I just need to find a receiver that says it has DLNA? Thanks Scott
Yes, look at UPnP as subset of DLNA specification. Any DLNA capable receiver should work, but it’s not a guaranteed. The are some discrepancies in the implementation among manufacturers and sometimes it doesn’t work.
