Hi, As far as I can see, My Audirvana only has the cog wheel for Settings, and there is no “Audio” sub-setting in which to install a MEqualizer vst3 equalizer plugin I downloaded to correct a hearing problem. In Settings there are only these: General, Library, Streaming, Sort Criteria, Maintenance, and Miscellaneous. Thanks for any help.
Click the speaker icon on the bottom right of main window to see dac settings, then the arrow on the right end.
Thank you very much, I have used Audirvana for years and this is a new world! I would have never discovered that by myself!
