I have a rather large ITunes library (22 k albums). I use ITunes integrated mode as I mainly add CDs to iTunes. Syncing in stand alone mode takes forever and often freezes Audirvana. Will the iTunes library continue to sync when in Integrated mode?
Hello @Raghu_Venkataraman,
If you are trying to syncrhonize the itunes media folder, when you start the synchronisation of your folder in Audirvana, do you still have iTunes opened?
Yes. I always have iTunes open.
Can you close iTunes while Audirvana is doing the synchronization?
I can try. Does it make a difference?
Yes it is as when you have iTunes open, it can interfere with the file you have, this is why the sync of Audirvana take so much time in your case.
I am not using the standalone mode and going back to Itunes intergrated mode, because Audirvana takes forever to sync to my large library.
I am on the latest Audirvana Mac Version macOS 11.3.0 with 8192MB RAM
To switch audio devices in Itunes integrated mode is a pain. I have two AMPs and two speaker set-ups.
Earlier you could switch it without getting out of Itunes integrated mode. Why is this gone?
Please re-instate the capability.
