When I play direct to laptop speaker I only have to press PLAY once. When connected to my network streamer I often have to press PLAY twice (also sometimes if I jump to the next track). When I press PLAY the second time I get initialising audio devices message.
Hello @Hugoman56,
Audirvana 3.5.2
Max allowed volume: 15.7037
AUTO: C:\Users\ijoll\OneDrive\Music
Library database path: C:\Users\ijoll\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Ian’s tunes Model UID:Cambridge Audio Ian’s tunes UID:uuid:fd9f6c26-eda2-4a4a-96ba-7e735c514745
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.1.68:8050/fd9f6c26-eda2-4a4a-96ba-7e735c514745/description.xml
Ian’s tunes Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 2
MediaDuration: 0:02:39
CurrentURI: http://192.168.1.110:49152/audirvana/audio_0_13.wav
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI: http://192.168.1.110:49152/audirvana/audio_1_14.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Ian's tunes Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3475 uuid:fd9f6c26-eda2-4a4a-96ba-7e735c514745 002027f6 image/png 48 48 8 /fd9f6c26-eda2-4a4a-96ba-7e735c514745/CA-roundal-48x48.png image/jpeg 48 48 24 /fd9f6c26-eda2-4a4a-96ba-7e735c514745/CA-roundal-48x48.jpg image/png 120 120 8 /fd9f6c26-eda2-4a4a-96ba-7e735c514745/CA-roundal-120x120.png image/jpeg 120 120 24 /fd9f6c26-eda2-4a4a-96ba-7e735c514745/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RenderingControl/RenderingControl1.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RenderingControl/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ConnectionManager/ConnectionManager1.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ConnectionManager/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ContentDirectory/ContentDirectory1.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ContentDirectory/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /fd9f6c26-eda2-4a4a-96ba-7e735c514745/AVTransport/AVTransport1.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/AVTransport/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaRadio/RecivaRadio.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaRadio/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /fd9f6c26-eda2-4a4a-96ba-7e735c514745/UuPlaylist/Playlist.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/UuPlaylist/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaSimpleRemote/RecivaSimpleRemote.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaSimpleRemote/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /fd9f6c26-eda2-4a4a-96ba-7e735c514745/StreamMagic6/StreamMagic6.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/StreamMagic6/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /fd9f6c26-eda2-4a4a-96ba-7e735c514745/SMSearch/SMSearch.xml /fd9f6c26-eda2-4a4a-96ba-7e735c514745/SMSearch/invoke /fd9f6c26-eda2-4a4a-96ba-7e735c514745/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0Ian’s tunes UID: uuid:fd9f6c26-eda2-4a4a-96ba-7e735c514745 Location: http://192.168.1.68:8050/fd9f6c26-eda2-4a4a-96ba-7e735c514745/description.xml
Max. memory for audio buffers: 9294MB
Local Audio Engine:WASAPI
Device #0: Speakers / Headphones (Realtek High Definition Audio) Manufacturer: Model UID: Speakers / Headphones (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b3bd3604-0fb8-450c-8f99-36a9493a6ad2}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Thanks, just downloaded the update. No improvement. Target volume limit still being overriden and app keeps reinitilalising if track changed manually.
Okay, since the fix we made was for the UPnP connectivity in general with Audirvana, that mean your problem is different from the other report we had. This is a confirmation that its a Cambridge problem, you should contact them to know if they have a fix for it because your DAC don’t respond to the play function we send to it.
Yes, I’ve told them the problem was probably at their end. They’ve taken it under advisement
Hey @Hugoman56 , have you resolved the issue? It’s seems it happening to me too on CA CXN V2 (I have to push play twice).
Several software updates later and still not fixed by CA (and it was them who told me to try audirvana!
So it’s not only me
Thanks for info.
