Recently purchased Audirvana, was much enjoying the giant leap forward in SQ from iTunes when trouble arose… For whatever reason, Audirvana began doubling everything when it loaded. So, for instance, I went from 100 albums and 1000 songs, then 200 albums and 2000 songs. Then it doubled when restarted, then doubled that again! I removed the harddrive from the library and tried to re-sync. No dice, same problems.
So I attempted to remove Audirvana to reinstall. It kept an original proto-version of the library and would not update, and it kept in sync with an old version of my library even though nothing shows as being sync’d. So, I downloaded a program to find and remove everything Audirvana then downloaded anew, and without sync’ing anything I get the same proto-library listing. Then I removed and de-authorized, then re-downloaded 24 hours later and tried again… same thing.
So how the heck do I start over again, where is this ‘library’ hidden, I can’t find anything, anywhere on my computer? Is there any remedy to doubling files and ghost libraries? Please help…
Does anyone here know how to clear out Audirvana completely from a Mac and restart from the ground up? I guess with no answer in two weeks from Audirvana or the forum, I’m just screwed?
If you have Playlists that are important export them first to desktop and
save them in a folder… when A+ is reset, you can re-import them back.
sadly to this day, the folders they were in is not back, you have to do it again…
Before doing this, maybe you should not connect after deleting those files to Roon or others…
Install A+ alone with your database… if working, log to Roon or else after.
Starting for new A+:
Trash All the files in that folder from A+ (that folder install SysOptimizer)
Trash All the files in that folder from A+ (SystemOptimizer and prefs files)
Trash All the files in that folder (that is your database of music, back it up!)
Go to User… Home Folder… Library… Cookies…
Trash com.audirvana.Audirvana-Plus.binarycookies
trash com.audirvana.Audirvana-Plus.plist in that folder (those are A+ software preferences)
Go to User… Home Folder… Library… Caches… com.audirvana.Audirvana-Plus
trash the files in that folder
Restart MAC. This will reset pretty much Audirvana like new.
When choosing library at first it will sync in top right main window under the logo…
LET IT GO, even better don’t try to adjust windows or edit files, even playing music
while it is not finished… you’ll see the progress bar going… Could be long the first time
depending on how large your library is, and MAC is fast or not…
