Windows 10 Enterprise LTSC. The download link does not start for Firefox, Opera, or Internet Explorer.
The pop up to start the download/install is not coming up on my system. Is there not a way to download the software directly?
Do you have App installer in your computer?
Since you are on LTSC it may be different for you:
How to install UWP (Modern UI) apps on Windows 10 LTSC/LTSB: https://tech.andrefelipe.net/2019/02/how-to-install-uwp-modern-ui-apps-on-windows-ltsc.html
Install Microsoft Store Apps on Windows 10 LTSC: https://www.jonandnic.com/2020/11/30/install-microsoft-store-apps-windows-10-ltsc/
No App Installer on the PC. Both those options require me to get the direct link to the app in the Microsoft store to access the .appx I could not find Audirvana in the MS store to follow either suggestions.
