Bonjour,
voici
Audirvana Studio 2.3.1 (20301)
Windows 11 (22621) with 16GB physical RAM
Connected account of : Thierry Maréchal
AUTO: D:
Library database path: C:\Users\Thierry\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 1115
Listening on 192.168.0.6 on port 49845
Qobuz: Connected as Membre Qobuz
Max. memory for audio buffers: 8192MB
Haut-parleurs (GUSTARD USB AUDIO)
Model UID:USB\VID_292B&PID_C4B3&REV_0001&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{cc8a71d3-6305-403c-8521-eddf4d287ad7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Haut-parleur (Conexant ISST Audio)
Manufacturer: Conexant
Model name: Intel High Definition Audio
Model UID: INTELAUDIO\FUNC_01&VEN_14F1&DEV_2008&SUBSYS_103C837D&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{50c1fc7d-7161-49a2-ab77-c28e11de396f}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
Max volume alert: Disabled
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
6 ch Integer PCM 16bit little endian 48kHz
6 ch Integer PCM 24bit little endian 48kHz
6 ch Integer PCM 16bit little endian 96kHz
6 ch Integer PCM 24bit little endian 96kHz
6 ch Integer PCM 16bit little endian 192kHz
6 ch Integer PCM 24bit little endian 192kHz
6 ch Integer PCM 16bit little endian 44.1kHz
6 ch Integer PCM 24bit little endian 44.1kHz
6 ch Integer PCM 16bit little endian 88.2kHz
6 ch Integer PCM 24bit little endian 88.2kHz
6 ch Integer PCM 16bit little endian 176.4kHz
6 ch Integer PCM 24bit little endian 176.4kHz
Device #0: Haut-parleur (Conexant ISST Audio)
