Even better than my Sonicake?
I like Bricasti but I would prefer this less expensive one from the Professional Line:
Matt
LiquidSonics Reverberate has a very nice Bricasti simulation/emulation for a plugin…
Actual measurements show lowest distortion at DSD512 for a number of DACs with Audirvana’s filter and modulators. I’ll take hard numbers over marketing (even from Bricasti, which makes lovely DACs), thank you.
Edit: The measurements I’ve seen were done with DACs that were not DSD1024 capable, so I don’t have numbers for comparison there.
Jud,
do you have a link to these measurements?
Thx
Matt
I’d posted a couple of links in another topic here. Let me see if I can find that comment. If not, I’ll look for the original source pages in another forum.
@Jud
Spare us the futile attempt at trying to be right… show us there is contextually tangible audible characteristics, that are conveyed via DSD512 and DSD1024 modulated iterations of a lower sample-rate DSD256 recording, as perceived by a cross-section of human-being audiophiles.
As the graphs show, this business about the DAC “running at the red line” is horse hockey. “Running at the red line” would imply more noise and distortion, and in the graphs we see conclusively there is less. (It makes perfect sense if you understand what’s going on inside the DAC. With some DACs the workload with DSD256 or DSD512 input is less, because the DAC chip doesn’t have to do the upsampling and modulation steps. With other DACs, the workload is very much the same as other inputs. If these things were not true, those graphs would look quite different.)
@matt read the whole thread to keep it in context…
Yes, yes, yes… we’ve been down this road… I will take the onboard Bricasti DSP any day over my MBP running r8Brain… A dedicated ASIC or FPGA is hard to beat in software…
Edit:
The Bricasti 8x up-sampling will take a DXD (352.8kHz) file to 2.8MHz … I’ll take their filtering DSP over r8Brain any day…
At the last or second-last RMAF, a friend who’s a designer for Sonore played a recording of his girlfriend, a singer. Of course he knew her voice intimately, and he knew the session details down to the mic used, The system he played it through used an amplifier he’d built and a lovely Bricasti DAC. And oh yes, he chose to use Audirvana’s upsampling rather than the Bricasti DSP after doing measurements and listening closely.
Of course it’s just one person and what does he know, right? ![]()
He knows his preferences… ![]()
Still doesn’t qualify the DSD12 vs DSD256 statements… ![]()
Indeed, software upsampling with a computer can beat, indeed, any DSP of any DAC. In this regard, the DSP of a DAC is always a compromise. It willnever be able to run the optimal algorithms.
I can’t say for r8Brain vs the Bricasti, but some modulators of HQPlayer are so CPU demanding that even a M1 Mac can not do more than DSD256 with them.
Same with Audirvana’s filters and modulators. CPUs are far more capable than FPGAs and ASICs, otherwise they’d put FPGAs and ASICs in computers. The reason CPUs (or GPUs, which would also be very suitable) aren’t used in DACs is simply expense.
You are completely right.
The impossibility to put a gaming PC inside the DAC pushed the designers of high-end DACs to engineer them to work at low frequencies of DSD, and high-grade, expensive electronics. A Nagra HD DAC is limited to DSD128, but it costs €25,000!
With its FPGA, the Dave is an exception among them, but it’s the only high-end DAC that is supposed to reach its optimal performance with an external upsampler (the MScaler). And even the MScaler can not match software DSP by a computer.
Please provide a link for this claim, afaik this is not correct.
Matt
Yeah, he’s got his PCM and delta-sigma processing mixed up.
