My iMac is connected to Goldnote DS-10 Plus via ethernet on uPnP mode. When I play DSD 64, GoldNote converts to PCM 88.2kHz with sound quality drops quite a lot. On the manual of GoldNote, via network uPnP, it is able to play up to DSD 64. I have tried both DoP 1.0 and DoP 1.1, but none worked so far. Is there any other setting I have to make changes?
Audirvana Origin 1.0.5 (10005)
macOS Version 12.4 (Build 21F79) with 16GB physical RAM
Bandwidth at 0dB = 99.5%
Phase = 66%
Sync list: 7 folders
AUTO: /Volumes/Music4T/24-96
AUTO: /Volumes/Music4T/24-192
AUTO: /Volumes/Music4T/DSF
AUTO: /Volumes/Music4T/Flac
AUTO: /Volumes/Music4T/Hi-Res
AUTO: /Volumes/Music4T/iTunes
AUTO: /Volumes/Music4T/WAV
Library database path: /Users/saransahabunyakul/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52350
Preferred device: GOLD NOTE DS-10 Model UID:GOLD NOTE DS-10 UID:uuid:308FD79C-1DD2-11B2-AA9E-985E1B007724
Currently playing to UPnP device at 24 bits 2822.4kHz
UPnP device at http://10.0.1.190:38400/description.xml
ID 0x0 DS-10
Manufacturer: GOLD NOTE
Model Name:
Model UID: GOLD NOTE DS-10
UID: uuid:308FD79C-1DD2-11B2-AA9E-985E1B007724
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::audio/mp4:DLNA.ORG_PN=MP4
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/ac3:
http-get::audio/x-dsf:
http-get::audio/x-wav:
http-get::audio/x-dff:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:12:13
CurrentURI: http://192.168.1.4:49152/audirvana/audio_0.dff
CurrentURIMetadata:
dc:titleLSO-Mendelssohn_A-Midsummernights-Dream_01</dc:title>
upnp:albumArtURIhttp://192.168.1.4:49152/audirvana/artwork_0_0.jpg</upnp:albumArtURI>
upnp:albumMENDELSSOHN – A MIDSUMMER NIGHT’S DREAM – INCIDENTAL MUSIC, OP. 61 & OVERTURE, OP</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget CurrentPlayMode string NORMAL REPEAT_ALL REPEAT_ONE SHUFFLE NORMAL RecordStorageMedium string NOT_IMPLEMENTED LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string NOT_IMPLEMENTED CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string CurrentTrack ui4 0 4294967295 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string NETWORK CurrentTransportActions string RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED PossiblePlaybackStorageMedia string AVTransportURIMetaData string NumberOfTracks ui4 0 4294967295 A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_COUNT A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string TransportStatus string OK ERROR_OCCURRED vendor-defined TransportPlaySpeed string 1 vendor-definedCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 DS-10 GOLD NOTE http://www.goldnote.it This model is a connected audio module which supports the UPnP/DLNA standard DS-10 CDMCM-210-001 uuid:308FD79C-1DD2-11B2-AA9E-985E1B007724 http://www.goldnote.it DMR-1.50 image/png 48 48 24 /images/small.png image/png 120 120 24 /images/large.png image/jpeg 48 48 24 /images/small.jpg image/jpeg 120 120 24 /images/large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /service/RenderingControl1.xml /service/RenderingControl_control /service/RenderingControl_event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /service/ConnectionManager1.xml /service/ConnectionManager_control /service/ConnectionManager_event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /service/AVTransport1.xml /service/AVTransport_control /service/AVTransport_event CDM212110200478 http://10.0.1.190:38400UPnP devices found : 2
Device #0: ID 0x0 DS-10 UID: uuid:308FD79C-1DD2-11B2-AA9E-985E1B007724 Location: http://10.0.1.190:38400/description.xml
Device #1: ID 0x0 55FX700_Series UID: uuid:4D454930-0100-1000-8001-80C755AE8F30 Location: http://192.168.1.23:55000/dmr/ddd.xml
Max. memory for audio buffers: 15360MB
Device #0: ID 0x2f AirBeamTV Audio Manufacturer: AirBeamTV B.V. Model UID: AirBeamTVDevice_ModelUID UID: AirBeamTVDevice_UID Model Name: AirBeamTV B.V. AirBeamTV Audio
Device #1: ID 0x48 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Built-in Output
