Hi,
Am using ifi Zen One Signature as my main DAC connected to my windows 11 pro pc. In Audirvana Origin the Dac is not able to play DSD as native but it is doing DSD over PCM 1.0/1.1 and is limited to 64 and 128 but not 256, though my dac has native DSD256 capabilities.
Also when I set the output as ASIO the DSD is turned off on Native and MQA is not being detected.
If I select as Kernel Streaming then the MQA is being detected as a Decoder. But DSD Native is still not there.
Only if I select it as DSD over PCM 1.0/1.1 then only DSD 64 and 128 is turning on. I know DSD over PCM gets half of what the deviceās max DSD bit support.
Also my debug log here:
Audirvana Origin 2.1.0 (20100)
Windows 11 (22621) with 8GB physical RAM
Connected account of : Satyajit Dey
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\satya\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.150.13 on port 59526
Max. memory for audio buffers: 1206MB
Local Audio Engine: ASIO 2
Driver version 1292
iFi USB Audio Device
Model UID:iFi USB Audio Device
Selected device:iFi USB Audio Device
Manufacturer:
Model name: iFi USB Audio Device
Model UID: iFi USB Audio Device
Device #0: iFi USB Audio Device
Manufacturer:
Device #1: Realtek ASIO
Manufacturer:
Model UID: Realtek ASIO
UID: Realtek ASIO
Model name: Realtek ASIO
UPnP devices found : 1
Device #0: 32ES500_Series
UID: uuid:4D454930-0100-1000-8001-D8AFF1B22097
Manufacturer: Panasonic
Model name: Panasonic VIErA
Chromecast devices found : 1
Device #0: TV
Model name: BRAVIA 4K VH2
Please let me know how I can solve this issue.
