Hi…just joined and this would be my first post. First, love Audirvana, made more of a difference (positive that is) than I expected. My small issue pre-dates Audirvana so this is not a problem w/ it. Previously I had all my music ripped, full resolution, to my Mac Mini. When upsampling to DSD 64 or 128 using JRiver I’d always hear vinyl sounding pops. Now w/ this year’s Mac Mini and Audirvana I’m hearing the same pops. My DAC is the Wyred 4 Sound DAC, the one that’s one step below the 10th Anniversary model but has the ESS 9038 Pro installed instead of the 9028. Thanks!
Hi @Wayne,
Welcome…
It is always important to manage the gain structure of the digital-audio signal so to prevent clipping distortion noise… When modulating (upsampling) PCM to DSD the process adds gain…
In the upsampling settings, you will see an option to reduce the gain before upsampling… Try reducing the gain by -3dB.
Do not add gain by using the digital-audio volume control if your system employs a pre-amp/amp with a volume control… use the hardware volume control if this is the case.
You may also be experiencing an intermittent distortion condition inherent to some digital-audio mastering processes in productions that have been normalized to maximize the loudness of the signal… These are called Inter-Sample Peaks (ISP’s)… So again, managing your gain structure in the Digital Signal Processing (DSP) functions that may also include Audio Unit plugins, and any Volume processing from input to output will give you the best possible playback sound-quality from your system.
Make sure you have set the mute between sample-rate changes enabled..
“Pop” goes DSD? Why does this happen?
Here you go:
Audirvana Studio 2.9.3 (20903)
macOS 15.0.1 ARM64 with 8GB physical RAM
Connected account of : David Lindblom
Local network access: allowed
r8brain to DSD128 with filter type B 8th order
Sync list: 0 folders
Library database path: /Users/davidlindblom/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 842
Listening on on port 49497
Font size: regular
My Music
Radios
Podcasts
Streaming
Startup view: My Playlists
Use media keys for volume control: no
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: no
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Wyred 4 Sound 32bit 384kHz Dsd Interface
Model UID:32bit 384kHz Dsd Interface:27F7:1301
UID:AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz Dsd Interface:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
Selected device:32bit 384kHz Dsd Interface
Manufacturer: Wyred 4 Sound
Model name: Wyred 4 Sound 32bit 384kHz Dsd Interface
Model UID: 32bit 384kHz Dsd Interface:27F7:1301
UID: AppleUSBAudioEngine:Wyred 4 Sound:32bit 384kHz Dsd Interface:413-001:2
USB Vendor ID: 0x27f7
USB Product ID: 0x1301
ID 0x31
32000
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x32 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 3
Device #0: ID 0x11e LG TV SSCR2
Manufacturer: GSM
Model UID: 1E6D0100-0000-0000-0121-010380A05A78
Model name: GSM LG TV SSCR2
Device #1: ID 0x31 32bit 384kHz Dsd Interface
Device #2: ID 0x52 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
I started w/ -3db but have tried the others too. -5db “seems” to be a little better. I use the W4S DAC’s digital volume control…and yes I want a real preamp but money…
It’s funny each song has different amounts of these little pin prick pops. It’s like each song is a different record. Speaking of which, that other forum posting is mostly about pops between songs, mine run randomly thru the songs lightly in the background. Often totally absent in long parts of songs. I posted my Debug report to Antoine’s post.
Firstly i would hurry up to update Sequoia to 15.1 released earlier…
This may be related to ISP’s… reduce the gain by -6db… If you continue to hear these distortions, it is probably inherent in the source file…
Try reducing the pre-load memory buffer to 2GB…
macOS Sonoma and Sequoia are memory hogs… Sonoma uses 20GB of disk space… The more RAM you make available to the Operating System the better… You are allocating 5GB of your 8GB available RAM for Audirvana pre-load buffering… This behavior appears to be either related to anemic RAM availability or gain structure related and/or ISP’s.
The debug report looks normal and nothing sticks-out that will precipitate the behavior you are experiencing…
You can try upsampling all PCM files using the ‘Power of Two’ option, as the ESS chipsets convert everything (DSD included) to multi-bit PCM for output anyway…
But try reducing your pre-load RAM allocation and reducing the gain before upsampling by -6dB first… ![]()
*Note:
1-bit is equivalent to 6dB dynamic range. The theoretical LPCM digital-audio dynamic-range is calculated as follows: [ 6 (dB) x (number of bits) + 1.75 (mv) ] (Example: 6 x 32bits + 1.75 = 193.75dBmv Theoretical ) Obviously no DAC is capable of reproducing a signal with this dynamic range… Real-world expectations in some modern DACs is getting close to 130dB of dynamic-range.
Been busy of late but thanks for all your suggestions. Implemented them all and it’s a little better. I have a sneaking hunch it’s the W4S DAC. I’ll keep fiddling but most of my listening is, as you suggested, via the “power of 2”.
