Yes, its only happens when pressing stop with dsd conversion option enabled.(PCM to DSD)
When pressing pause, it does not happen.
It also does not happen in the OSX version of Audirvana.
It also does not happen in Jriver ( windows or osx version)
It also does not happen with native DSD playback on Audirvana.
It only happens with Windows 10 Audirvana, with DSD conversion option enabled (see screenshot)
Upsampling:
SoX to DSD256 with filter type B 8th order
Phase = 73
Library Settings:
AUTO: D:\Muziek
Library database path: C:\Users\Johan\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Active streaming services
Qobuz: ON
Local Audio Engine:WASAPI
Preferred device: Digitale uitvoer (Chord Async USB 44.1kHz-768kHz) Model UID:Digitale uitvoer (Chord Async USB 44.1kHz-768kHz) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{db912e02-74cc-419d-8a68-4bc8a91892a0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Digitale uitvoer (Chord Async USB 44.1kHz-768kHz) Manufacturer:
Physical (analog) volume control: No
Virtual (digital) volume control: No
Simple stereo device: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
2 ch Integer PCM 24bit little endian 705.6kHz
2 ch Integer PCM 24bit little endian 768kHz
Device #0: luidspreker/Hoofdtelefoon (Realtek High Definition Audio) Manufacturer: Model UID: luidspreker/Hoofdtelefoon (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e55cccf0-9426-48ec-bb5b-37e0bde523cb}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Digitale uitvoer (Chord Async USB 44.1kHz-768kHz) Manufacturer: Model UID: Digitale uitvoer (Chord Async USB 44.1kHz-768kHz) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{db912e02-74cc-419d-8a68-4bc8a91892a0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0CHORD UID: uuid:66311246-b60b-4b55-b682-35dde1c92199 Location: http://10.0.0.62:52101/DeviceDescription.xml
![screenshot.jpeg](/uploads/default/original/1X/42de543da6556df3962438e447a18f577fe5b15c.jpeg)
