DSD - DoP issues with Denafrips DAC
Audirvana Studio
MacBook Pro 2019
Denafrips Ares II DAC
USB C to USB B connection to DAC
Audirvana Studio recognizes the DAC and the DSD compatibility in the audio setup screen.
But selecting DoP for DSD playback causes the app to crash the moment you push Play for any DSD track.
Error message comes up on app restart that Audirvana needs accessibility turned on in Mac system preferences, but it is already selected and a trusted app.
I have restarted both the DAC and laptop, uninstalled and reinstalled software to no avail.
Can you dump the debug info here?
Hi, I am not sure if this is correct. A terminal window opens when the app restarts with the following message. Is this the debug info?
Last login: Fri Mar 18 17:58:48 on ttys001
The default interactive shell is now zsh.
To update your account to use zsh, please run chsh -s /bin/zsh.
For more details, please visit Use zsh as the default shell on your Mac - Apple Support.
CAllen-mbp-2629946:~ callen$ /Applications/Audirvana\ Studio.app/Contents/MacOS/Audirvana\ Studio ; exit;
2022-03-18 19:44:44.611 Audirvana Studio[2085:38639] Mediakeys listening: error getting event Port
2022-03-18 19:46:00.232 Audirvana Studio[2085:38824] UPnP: Error obtaining device description from http://192.168.100.3:49152/wps_device.xml – error = -204
2022-03-18 19:46:00.232 Audirvana Studio[2085:38825] UPnP: Error obtaining device description from http://192.168.100.3:49152/wps_device.xml – error = -204
I am not sure where specifically debug information is kept.
No that’s not your debug, I’ve never seen that on Mac, don’t do anything till @Antoine or one of the tech guys on the forum answer about that terminal screen
I’m probably just paranoid but safe than sorry, you can get your debug if the program is running, from one of the preferences/ settings panes
Sorry to say but won’t get Audirvāna support until next week their only guy has weekends off
Yay, I found the debug finally:
Audirvana Studio 1.12.0 (11200)
macOS Version 11.4 (Build 20F71) with 16GB physical RAM
Connected account of : Cabe Allen
AUTO: /Users/callen/Downloads/DSD Audio Files
Library database path: /Users/callen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50630
Max. memory for audio buffers: 13848MB
Exclusive access: Disabled
DENAFRIPS DENAFRIPS USB AUDIO V3.12
Model UID:DENAFRIPS USB Audio V3.12:152A:86EF
UID:AppleUSBAudioEngine:DENAFRIPS :DENAFRIPS USB Audio V3.12:14400000:1
Active Sample Rate: 176.4kHz
ID 0x59 DENAFRIPS USB Audio V3.12
Manufacturer: DENAFRIPS
Model Name: DENAFRIPS USB Audio V3.12
Model UID: DENAFRIPS USB Audio V3.12:152A:86EF
UID: AppleUSBAudioEngine:DENAFRIPS :DENAFRIPS USB Audio V3.12:14400000:1
12 available sample rates up to 1536000Hz
1411200
1536000
Audio buffer frame size : 53 to 4096 frames
Stream ID 0x5a 2 channels starting at 1
24 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Float 1411.2kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
24 physical formats
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1536kHz
2 ch Mixable linear PCM Interleaved 32 little endian Signed Integer 1411.2kHz
Device #0: ID 0x59 DENAFRIPS USB Audio V3.12 Manufacturer: DENAFRIPS Model UID: DENAFRIPS USB Audio V3.12:152A:86EF UID: AppleUSBAudioEngine:DENAFRIPS :DENAFRIPS USB Audio V3.12:14400000:1 Model Name: DENAFRIPS USB Audio V3.12
Device #1: ID 0x4d MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
Drop your buffer down to 4000mb , that’s usually the first thing to dial in. Perhaps @bitracer will drop back by and see something, otherwise wait till Monday in Paris time………not that you wanted to use your system over the weekend :wink:
thank you. appreciate the help
Have you tried to select ā€œNativeDSDā€? Sounds like a driver issue. If it still doesn’t work, re-install the driver.
Try this driver:
https://wix.anyfileapp.net/dl?id=553246736447566b58313963795234374e4b617931525067384a7a4771306773534b304f4e4d775875577579637869463177346a504752792f654977597938656c3864707a695664503961736e5156457435362f33673d3d
https://www.denafrips.com/download-ares
Ahh sorry, you’re on a Mac. Try DoP 1.1. What kind of DSD resolution you’re trying to play?
Both 64 and 512. A competing software plays both with no issues. I am guessing this is a software issue versus a hardware issue.
DSD64 should work no issues. With DSD512 it’s a bit tricky with DoP. Do you really have files in that resolution or you’re upsampling?
Hello @cabeallen,
Can you please send us the crash generated when you have your issue at [email protected]?
You need go in the Console app of MacOS to find it :wink:
