Audirvana Mac Version 3.5.41 (3571)
macOS 10.13.6 with 2048MB RAM
Registered to tsammyc
SoX custom frequencies
AUTO: /Users/tsc/Downloads/ISOs
Library database path: /Users/tsc/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 256MB
E30
Model UID:E30:152A:8750
UID:AppleUSBAudioEngine:Topping:E30:fa130000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 705.6kHz
Active Sample Rate: 705.6kHz
Hog Mode is on
ID 0x3d E30 Manufacturer:Topping
Model UID:E30:152A:8750 UID:AppleUSBAudioEngine:Topping:E30:fa130000:1
Audio buffer frame size : 231 to 4096 frames
Stream ID 0x3e 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x33 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:98 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x3d E30 Manufacturer: Topping Model UID: E30:152A:8750 UID: AppleUSBAudioEngine:Topping:E30:fa130000:1
UPnP devices found : 1
Device #0: ID 0x0 DP-UB820 UID: uuid:4D454930-0100-1000-8000-80C755E7EE6B Location: http://192.168.1.54:60606/80C755E7EE6B/Server0/ddd
