Hi, it is Audirvana using DoP to work with Native DSD? or it is completely native?, thanks.
Depends in the operating system and the driver you use. On the MacOS it’s DoP only.
Hello,
DoP keeps DSD completely native.
DoP is not an encoding or decoding process, it allows to carries the DSD stream in a way made for PCM, but the DSD stream is not modified.
