Hi,
I need help, I searched a lot, and tried a lot… but didn’t succeed.
Running Audirvana on OSX, tried connection to receiver with Toslink (MacMini optical out) and HDMI.
Playback of DSF file with DSD128 (Stereo) doesn’t playback in DSD128.
Receiver supports DSD, but audirvana says: DSD not supported.
Enclosed screenshot during playback:
And my debug infos:
macOS 10.13.6 with 16384MB RAM
Sync list: 3 folders
AUTO: /Volumes/_SOUNDPOOL/SOUNDPOOL_CLASSIC_HRES_MC
AUTO: /Volumes/_SOUNDPOOL/SOUNDPOOL_CLASSIC_SACD_MC
AUTO: /Volumes/_SOUNDPOOL/SOUNDPOOL_CLASSIC_SACD_ST
Library database path: /Users/kopi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HDMI
Model UID:AppleHDA:108
UID:AppleHDAEngineOutputDP:3,0,1,1:0:{A934-A096-01010101}
ID 0x27 Ausgang (integriert) Manufacturer:Apple Inc.
Model UID:AppleHDA:108 UID:AppleHDAEngineOutput:1B,0,1,2:0
7 available sample rates up to 192000Hz
32000
Stream ID 0x28 2 channels starting at 1
7 virtual formats:
21 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x27 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x32 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{A865-3190-00000000}
UPnP devices found : 2
Device #0: ID 0x0 RX-A1030 UID: uuid:5f9ec1b3-ed59-1900-4530-00a0dea15d99 Location: http://192.168.0.14:8080/MediaRenderer/desc.xml
Device #1: ID 0x0 [TV] LonniTV UID: uuid:28543d46-0bb6-474c-939b-b554830b87c8 Location: http://192.168.0.27:9197/dmr
Thank for help and/or guiding to correct settings…
If you need more logfiles… please let me know.
USB is the only way on most computers to play DSD, and your receiver does not have a usb input…
