DSD on Topping D30
Hey folks
I’ve an old topping d30 that’s supposed to play up to DSD128 (over DoP). The interface recognizes it, but if I play something there’s just clicks and then static. What could be wrong in this case?
Hi @heyhey,
SIGNAL PROCESSING
	Per track: OFF
Max. memory for audio buffers: 7530MB
D30
Model UID:D30:20B1:3066
UID:AppleUSBAudioEngine:Topping:D30:141400:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x63 D30 Manufacturer:Topping
Model UID:D30:20B1:3066 UID:AppleUSBAudioEngine:Topping:D30:2141400:1
Stream ID 0x64 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x54 DELL U2724DE Manufacturer: DEL Model UID: 10ACE242-0000-0000-2422-0104B53C2278 UID: 10ACE242-0000-0000-2422-0104B53C2278
Device #1: ID 0x63 D30 Manufacturer: Topping Model UID: D30:20B1:3066 UID: AppleUSBAudioEngine:Topping:D30:2141400:1
Device #2: ID 0x48 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
hmm… the thing is, the DAC doesn’t have any volume control at all…
okay I tried putting the volume at 100 (using controls on the desktop since there’s no volume control on the DAC itself). Then sound output is correct, music instead of static. But in its current state its unusable (wayyyy too loud) cuz I don’t have an external volume control. The speakers are powered studio monitors with no volume control.
