Hello!
I nave Topping D10s DAC connected through USB to my MacBook Air M1 with macOS Monterey and Audirvana Origin 1.0.3.
The problem is: when I trying to play any DSD files (64 or 128) using DSD over PCM 1.0 or 1.1 method, sometimes I hear ticks in sound (like when you listen vinyl and hear needle ticks). When I use Convert to PCM methods, the same files sounds good.
How to fix this problem, does anybody know? I want to listen DSD files
Debug Info:
Audirvana Origin 1.0.3 (10003)
macOS 12.3.1 with 16GB physical RAM
AUTO: /Users/max/Music
Library database path: /Users/max/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56772
Integer mode: Disabled
TOPPING D10S
Model UID:D10s:152A:8750
UID:AppleUSBAudioEngine:Topping:D10s:1100000:1
Active Sample Rate: 352.8kHz
ID 0x60 D10s
Manufacturer: Topping
Model Name: Topping D10s
Model UID: D10s:152A:8750
UID: AppleUSBAudioEngine:Topping:D10s:1100000:1
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x61 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x60 D10s Manufacturer: Topping Model UID: D10s:152A:8750 UID: AppleUSBAudioEngine:Topping:D10s:1100000:1 Model Name: Topping D10s
Device #1: ID 0x3c MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Air Speakers
Device #2: ID 0x59 eqMac Manufacturer: Bitgapp Ltd Model UID: EQMDeviceModelUID UID: EQMDevice Model Name: Bitgapp Ltd eqMac
