Hi,
I’ve been trying to play back DSD64 using an Earmen Donald Dac and when either DSD via PCM 1.1 or 1.0 are used I get a loud hissing sound and if I max out the volume on my headphone amp I’m able to barely make out the music playing in the background. From my understanding the Donald Dac supports native DSD decoding however there doesn’t appear to be an option for sending a direct DSD stream within the App. Below is the debug info while playing back a DSD track.
Audirvana 3.5.40
Effects plugins NOT ACTIVEUPSAMPLING:
Phase = 66AUDIO VOLUME:
SW volume control: OFFLIBRARY SETTINGS:
Sync list: 2 folders
AUTO: C:\Users\timothy.rose\Music
AUTO: C:\Users\timothy.rose\OneDrive\Music
Library database path: C:\Users\timothy.rose\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqliteACTIVE STREAMING SERVICES
TIDAL: Connected as HIFI=================== AUDIO DEVICE ========================
Max. memory for audio buffers: 5212MB
Local Audio Engine:WASAPI
Speakers (7- EarMen Donald DAC)
Model UID:Speakers (7- EarMen Donald DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{a3163a3b-d52f-4676-8f4f-79d309fe9ea0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}Currently playing in Integer Mode:
Device: 2ch 24bits Integer, 8 bytes per frame 176.4kHzActive Sample Rate: 176.4kHz
Mute during sample rate change: OFFSelected device:
Speakers (7- EarMen Donald DAC) Manufacturer:
Model UID:Speakers (7- EarMen Donald DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{a3163a3b-d52f-4676-8f4f-79d309fe9ea0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}8 available sample rates up to 384000Hz
MQA Renderer device
Channel 1 mapped to 1Audio channels in use
Simple stereo device: No1 output streams:
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 384kHzLocal devices found : 5
Device #0: Speaker/HP (Realtek High Definition Audio) Manufacturer: Model UID: Speaker/HP (Realtek High Definition Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{aabcc21a-8c9d-4bbf-835c-5d971a216f82}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Speakers (4- Logitech USB Headset H340) Manufacturer: Model UID: Speakers (4- Logitech USB Headset H340) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{e44e5c53-e800-43b1-b842-b6e80a3004e6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: ASUS VK278 (Intel(R) Display Audio) Manufacturer: Model UID: ASUS VK278 (Intel(R) Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{190edd0e-49ba-4b2a-ac0c-2e74cf2aa1e6}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: Speakers (7- EarMen Donald DAC) Manufacturer: Model UID: Speakers (7- EarMen Donald DAC) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a3163a3b-d52f-4676-8f4f-79d309fe9ea0}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #4: Speakers (Zorloo Ztella USB Audio) Manufacturer: Model UID: Speakers (Zorloo Ztella USB Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5f10ab0d-25d4-4d13-a985-a52f63000e4d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}UPnP devices found : 0
