Hi everyone,
I’m using MacAir 2015 8GB with Mojave 10.14.6. I’ve play DSD files through USB with SMSL SU-8 with no problems until last evening. Suddenly Audirvana doesn’t play any sound even though I can see the playing bar is counting seconds.
Here is my Debug info.
Please help. Thank you all.
Audirvana Mac Version 3.5.46 (3576)
macOS 10.14.6 with 8192MB RAM
Registered to XXX
Per track: OFF
Sync list: 0 folders
Library database path: /Users/xv/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
SMSL SU8 USB2.0
Model UID:SMSL SU8 USB2.0:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL SU8 USB2.0:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x52 SMSL SU8 USB2.0 Manufacturer:SMSL
Model UID:SMSL SU8 USB2.0:152A:85DD UID:AppleUSBAudioEngine:SMSL:SMSL SU8 USB2.0:14100000:1
Stream ID 0x53 2 channels starting at 1
20 virtual formats:
20 physical formats
Local devices found : 3
Device #0: ID 0x48 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:126 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x52 SMSL SU8 USB2.0 Manufacturer: SMSL Model UID: SMSL SU8 USB2.0:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL SU8 USB2.0:14100000:1
Device #2: ID 0x2d eqMac Manufacturer: Bitgapp Model UID: EQMDeviceModelUID UID: EQMDevice
Hello @h3nrymed,
You have no music content synced with Audirvana, can you try to add a folder and play to your SMSL?
Actually I play from my external HDD. I just drag a file from my HDD to “Playing list” then play it.
Everything works fine until last evening as I said in my first comment.
When I drag a DSD file into Playing list and hit play, the second counts but there was no sound. When I change to “Convert to PCM” then I can hear the music but with extremely loud noise accompanied.
I don’t know if it was the recent Mojave update pack or some software I installed recently.
Have you tried to remove the mute during sample rate change? You need to go in the audio output setting in Studio to deactivate it.
I tried to turn off the “Mute…” but nothing changed. Still no sound with DSD file.
When you have this issue, does the SMSL overheat? Do you have a different DAC that support DSD?
Thanks for your support. I have tried to reinstalled MacOS Mojave 10.14.6 and everything works smoothly again.
Maybe it was due to some softwares that I installed recently.
