I want to be able to convert DSD to PCM so I can use audio units plugin on the music. However, the option of ‘Native DSD method > None:Convert to PCM’ appears only on a 24/96 capable DAC, but it does NOT appear on my DSD capable DAC (which plays both PCM and DSD).
He’s my dac does have dsd playback up to 128 and this option shows when selecting. It is however only a 2 channel Dac. Yours stated it’s 4 channel and perhaps there’s the issue and you need to out in on 2 ch only?
Sorry for the very late reply. We identified in the past an issue in the DoP interpretation of MyTek when using a Firewire connection, this is why you can’t change the DoP setting, it is by default enabled internally by Audirvana.
Thank you, I think I understand now and I assume this will not be adjusted in a future version of Audirvana Studio because not many people use Firewire. Thank you for the “realtime” responses, it is appreciated.
