Hello. I’m having trouble with upsampling to DSD but only when I’m listening to music on my linked Qobuz account. The main problem is the track only loading until almost the end, so the track stops at the last second and doesn’t go to the next track. This is especially true when the track is long, like a 10 minute+ jazz track, for example. I am not having this problem when I listen to my own files off my hard drive. Any help with the settings so I don’t have this problem would be appreciated.
Hello @Anthony_Showalter,
Audirvana 3.5.45
VST3 plugin #0: C:\Program Files\Common Files\VST3\Reveal.vst3
ClassID: 56535452564C3172657665616C000000
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
Phase = 0
Replay Gain: by album
Sync list: 2 folders
AUTO: D:\Music
AUTO: D:\WAV_FLAC Files
Library database path: C:\Users\showa\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5744MB
Local Audio Engine:ASIO 2 driver version 1091
USB DAC ASIO
Model UID:USB DAC ASIO
UID:USB DAC ASIO
Device: 2ch 32bits Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
USB DAC ASIO Manufacturer:
Model UID:USB DAC ASIO UID:USB DAC ASIO
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: USB DAC ASIO Manufacturer: Model UID: USB DAC ASIO UID: USB DAC ASIO
Also, update. I seem to be having this problem with playback even when not upsampling to DSD while listening to Qobuz. Especially if the track is long it will not play the next track after the song is over.
Do you have the issue while you do not have your plugin activated? Can you give us examples of tracks or albums in Qobuz so we can try them on our side?
One track that is having this problem is “The Little House I Used To Live In” (192kHz version) by Frank Zappa off Burnt Weeny Sandwich on Qobuz. It’s a long song and it’s high sample rate, and after the song is over it won’t play the next track. I did not have any plugins enabled while listening to it just now and it didn’t still didn’t play beyond that track.
