DSD upsampling too long on some titles
Hi
New user, i am currently testing Audirvana studio and play music to a TEAC UD(701N via upnp/ openhome with DSD512 encoding.
Generally everything works fine.
but for for some title encoding take a very long time and may never finish ( stop during processing).
Environment:
Testing in a vm with Windows 11 pro/16 cores/16 GB
Test:
a good example in qobuz album ā€œStrozzi: Virtuosissima compositriceā€ (Album page on quobuz site- 96khz ( the result are identical between local files and streamed files, occurs with SOX or r8brain algorithm).
The first title ( ā€œHor che’l ciel e la terra e’l vento tace, SV 147ā€) take a long time to encode and never finish.
The fourth title (ā€œIl terzo libro de madrigali: Dispietata pietateā€) is played after 2 seconds without having to encode the full track.
CPU load is 20Ā£ to 25% , memory usage is 6GB .
IS there any explaination for the these discrepancies in track handling?
Thanls in advance for your answer.
Nota: as a 10 year user of hqplayer , i am familiar with some of DSD encoding requirements
Hi @jmaa,
Can you send us a copy of the ā€œDebug Infoā€ when you have this issue? You can get it in Audirvana Settings>My account
Track 1 start 14H25 end 14h28 no sound
Trac 4 start 14h30 stopped 14h32 sound ok
Only image files (jpg, … ) are allowed.
( 3 files , for 1MB )
ā€œaudirvana_studio.logā€
ā€œaudirvana-debug-data-track1.txtā€
ā€œaudirvana-debug-data-track4.txtā€
Where can i upload those files ?
or should i rename file extension from .txt to .txt.jpg to allow upload?
Thanks in advance
Please send them at [email protected]
