Hello,
when I try to play DSD64 files, I only get a sort of white noise with DoP (1 and 1.1 are the same). DSD128 works fine.
I updated to a iMac 2019.
Playing without DoP works…
Using a Fiio X3.
On my old Mac mini with IFI HD all works fine…
Audirvana Mac Version 3.5.39 (3569)
macOS 10.15.6 with 40960MB RAM
Registriert nach Sören Leupold
Sync list: 2 folders
AUTO: /Volumes/My Book/DSD
AUTO: /Volumes/My Book/Itunes/Music
Library database path: /Users/soerenleupold/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Connected as VirtualVault
Max. memory for audio buffers: 37888MB
FiiO X3
Model UID:FiiO USB Audio Class 2.0 DAC:2972:0001
UID:AppleUSBAudioEngine:SmartAction:FiiO USB Audio Class 2.0 DAC:0007:1
ID 0x2a FiiO X3 Manufacturer:SmartAction
Model UID:FiiO USB Audio Class 2.0 DAC:2972:0001 UID:AppleUSBAudioEngine:SmartAction:FiiO USB Audio Class 2.0 DAC:0007:1
7 available sample rates up to 192000Hz
32000
Stream ID 0x2b 2 channels starting at 1
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
14 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x33 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x2a FiiO X3 Manufacturer: SmartAction Model UID: FiiO USB Audio Class 2.0 DAC:2972:0001 UID: AppleUSBAudioEngine:SmartAction:FiiO USB Audio Class 2.0 DAC:0007:1
