DSD64 stops and jumps playback after ~1-2 minutes
Hi!
I have an issue when streaming DSD64 files from Synology NAS to my Primare CD15 Prisma (UPnP). Streaming of PCM files goes fine so far, but DSD stops playing after 1-2 minutes, or else may instantly switch to the middle of the next track, then turn back to the previous seamlessly. If I look to the playing track, progress bar is idle while track keeps playing.
Debug:
Audirvana Studio 2.10.1
Linux 4.4.302+ x86_64 (Synology NAS DS723+ DSM 7.2.2.72806 Update 3) x86_64 with 7.7GB physical RAM
Connected account of : Sergey Kurbatov
Manual: /volume2/Music
Sync folders at startup: YES
Sort and display order: en
Library database path: /var/packages/audirvana-studio/home/.local/share/audirvana/AudirvanaDatabase.sqlite
Fingerprinting track 317/1367 : /volume2/Music/Electronic/Bonobo/Live Albums/2014 - The North Borders Tour - Live/06 - Ten Tigers.flac
Listening on on port 42464
Font size: regular
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 2
Active method: UPnP
eth0
eth1
Preferred device: [UPnP] Primare CD15 Prisma Model UID:Primare PrimareCD15 UID:uuid:c52be184-f1df-11ee-a39a-0796165f73a6
Currently playing to UPnP device at 24 bits 2822.4kHz
Selected device:Primare CD15 Prisma
Manufacturer: Primare
Model name: PrimareCD15
Model UID: Primare PrimareCD15
UID: uuid:c52be184-f1df-11ee-a39a-0796165f73a6
UPnP device at http://192.168.1.71:38400/description.xml
Volume control: Yes
Max volume alert: Disabled
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD64
Avoid RAW PCM streams: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:
:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:
:audio/flac:*
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
http-get:
http-get:
:audio/aiff:*
http-get::audio/x-aiff:
http-get::audio/dsd:
http-get::audio/x-dsd:
DLNA 1.5: Yes
Native Gapless playback: Yes
Universal Gapless playback active: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
NrTracks: 1
MediaDuration: 0:00:00.000
CurrentURI: http://192.168.1.76:49152/audirvana/gaplessAudio_f_0.dff
CurrentURIMetadata:
dc:titleAudirvana gapless playback</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play
<?xml version="1.0"?> 1 0 DMR-1.50 QPlay:2 urn:schemas-upnp-org:device:MediaRenderer:1 Primare CD15 Prisma Primare http://www.primare.net/ PrimareDMR PrimareCD15 1.0 http://www.primare.net/products/CD15-prisma/ 1234567890 uuid:c52be184-f1df-11ee-a39a-0796165f73a6 [http://192.168.1.71](http://192.168.1.71/) urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay.xml /QPlay /QPlay/eventSub [http://192.168.1.71:38400](http://192.168.1.71:38400/)
UPnP devices found : 1
Device #0: Primare CD15 Prisma
Max. memory for audio buffers: 3958MB
Local Audio Engine: Linux ALSA library1.1.0
Local devices found : 0
Chromecast devices found : 1
Model name: Primare CD15
Hi @SStan,
Do you get this issue only with DSD 64 upsampling?
Most likely this related to the available System RAM… it appears you have the bare minimum recommended System RAM for Audirvāna operations… DSD files are very large and require large registers in addition to Ethernet packeting processing and buffering (including DoP processing/packeting if employed, prior to transmission via Ethernet) … You are allocating 50% (3.95GB) of your available System RAM for playback preload buffering… Lower this to 1GB
Note the bold text below:
(EDIT) Also, it appears that your DAC is converting 1-bit DSD signals to multi-bit DSD-Wide in the AKM AK4490 chipset… It appears the Primare box design is not implementing the pure 1-bit PDM (DSD) signal path available in the AKM chipset… the documentation shows that the box is capable of handling 2.8MHZ DSD64 and 5.6MHz DSD128 … make sure your firmware is up to date. The best you can do via DoP will be DSD64 as the DAC supports up to 192kHz PCM, as the DoP 1.0 PCM carrier sample-rate is 24/176.4kHz.
