I’m getting duplicate albums popping up with the tracks dispersed between the two (see photo). What do I need to do to prevent this? I tagged everything in the latest version of iTunes because tagging in AO took too long, and did not solve the problem.
Also, when I make mixes, AO places the music back to their original location rather than all together under one album title.
Audirvana Origin 1.0.5 (10005)
macOS Version 12.4 (Build 21F79) with 32GB physical RAM
Connected account of : RONALD BUCK
AUTO: /Volumes/PIPER 6/HiResLibrary/iTunes Media/Music
Library database path: /Users/ronbuck123/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51428
APPLE INC. RON BUCK’S BEATS STUDIO³
Model UID:2009 4c
UID:50-1F-C6-60-91-ED:output
ID 0x4a iMac Speakers
Model Name: Apple Inc. iMac Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x4b 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4a iMac Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. iMac Speakers
Having a “deterministic” indexing is critical… It is our very owned and curated library (vs the streaming giants out there…)
