Hi Guys,
This problem had stopped for a while however now it is back and is even more frustrating in that it now shows DAC output capability even for one of the ‘ghost’ duplicates.
I now have to start playing a track on each rx-3077 options to see if it works, previously the output capability under the volume adjust would show 0 if it was a duplicate ghost.
Audirvana is the only application/program that has this problem. As can be seen in the system output settings I have only the two sound output devices. For some reason audirvana duplicates my 3077 receiver.
debug and image below.
Kind regards,
Tim
Audirvana Studio 1.8.1 (10801)
Windows 10 (19043) with 12GB physical RAM
AUTO: I:\Music
Library database path:
Listening on 192.168.1.46 on port 49891
Max. memory for audio buffers: 3854MB
Local Audio Engine: WASAPI
RX-V3077 (NVIDIA High Definition Audio)
Model UID:MMDEVAPI\AudioEndpoints
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{41fdc0cf-607f-4140-a919-3a3543299e80}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Manufacturer: Microsoft
Model Name: RX-V3077 (NVIDIA High Definition Audio)
Model UID: MMDEVAPI\AudioEndpoints
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{41fdc0cf-607f-4140-a919-3a3543299e80}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
6 ch Integer PCM 16bit little endian 44.1kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 44.1kHz
6 ch Integer PCM 16bit little endian 48kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 48kHz
6 ch Integer PCM 16bit little endian 88.2kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 88.2kHz
6 ch Integer PCM 16bit little endian 96kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 96kHz
6 ch Integer PCM 16bit little endian 176.4kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 176.4kHz
6 ch Integer PCM 16bit little endian 192kHz
6 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHz
Local devices found : 9
Device #0: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5347273a-a8df-4c3a-9e46-a1acd804096d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #1: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{98221b36-c095-43bc-a523-a29a7645cb2b}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #2: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0704b1fd-143c-46da-ba74-ab0a7225b55b}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #3: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f4d1a969-9493-46bf-aa47-1e85bf52a616}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #4: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{4f3107a8-e9e5-44b8-9382-850d868ce8d4}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #5: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{771e9255-ff31-416f-a271-7e5cba921599}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #6: Speakers (EDIFIER G2000) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0de1c43e-d7c0-4c8f-8b21-7447879bf595}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers (EDIFIER G2000)
Device #7: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{41fdc0cf-607f-4140-a919-3a3543299e80}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
Device #8: RX-V3077 (NVIDIA High Definition Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{022a089c-098a-4ec2-a733-85cff60d689d}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: RX-V3077 (NVIDIA High Definition Audio)
