Hi there, can somebody help me get rid of these “ghost” tracks that suddenly appeared yesterday?
As you can see the day before it worked well (no playdate because there was only one instance at that time) but then next day when I continued listening to CD2, I’m was getting every track played twice. Checking the volume with the files, showed only one instance of each track.
Should I just discard the old database and build a fresh? My Audirvana log is also attached. Any thoughts?
Audirvana Studio 3.1.0 (30100)
Running on Macmini8,1
macOS 15.7.5 x86_64 with 16GB physical RAM
Connected account of : Lars Hansen
Local network access: allowed
REMOTE CONTROL SERVER:
Listening on
en0 IPv6: 2a13:8a02:a103:ec00:1427:5bc:2e2f:d18
en0 IPv4: 192.168.1.68
en0 IPv6: 2a13:8a02:a103:ec00::b
en1 IPv6: 2a13:8a02:a103:ec00:ce7:7a4b:a0dd:fa8c
en1 IPv4: 192.168.1.83
en1 IPv6: 2a13:8a02:a103:ec00::e
on port 64412
LOADING/DECODING:
Max audio buffer size: 10782MB
Per track: OFF
Convolver: OFF
Internal EQ: OFF
Crossfeed: OFF
Balance: OFF
PLUGINS: NOT ACTIVE
Volume step size: 1.5dB
Sync list: 3 folders
AUTO: /Users/larshansen/Documents/Musik/Audio Tracks
AUTO: /Volumes/Data/Musik/Audio Tracks
AUTO: /Volumes/Data/Musik/iTunes Max/iTunes 1/iTunes Media/Music
Sync folders at startup: YES
Sort and display order: en
Library database path: /Users/larshansen/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 4081
Font size: regular
Streaming
Favorites
Playlists
Podcasts
Radios
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 10782MB
CoreAudio
Exclusive access: ON
Integer mode: ON
Apple, Inc. AirPlay
Model UID:a5fc0a05-208a-4fc2-9e25-37a284833cd5-102218543202-Audio
Selected device: WAVELIGHT DAC
Manufacturer: ROCKNA
Model name: ROCKNA WAVELIGHT DAC
Model UID: WAVELIGHT DAC:16D0:078C
UID: AppleUSBAudioEngine:ROCKNA:WAVELIGHT DAC:413-001:2
Plays with Audirvāna: No
USB Vendor ID: 0x16d0
USB Product ID: 0x078c
ID 0x63
32000
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x64 2 channels starting at 1
18 virtual formats:
18 physical formats
Local devices found : 3
Device #0: ID 0x6d Philips FTV
Model UID: AppleGFXHDA:0
UID: AppleGFXHDAEngineOutputDP:f803:0:{0C41-0000-01010101}
Model name: Apple Inc. Philips FTV
Device #1: ID 0x63 WAVELIGHT DAC
Device #2: ID 0x5d Højttalere i Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Højttalere i Mac mini
Selected Network interface: Ethernet
Ethernet
Wi-Fi
