I am on a trial and liking what I see.
But! I changed a set of files’ composer, saved, and it only partially worked. The Composer field is now empty. But When I sort by Composer the original entry continues to be displayed.
Hello @Fuga,
Which version of Audirvāna Studio/Audirvāna Origin are you using? The Windows or MacOS version?
HAha, yeah that might be pertinent.
macOS 12.3.1
Okay, can you please send screenshots of the steps you have done so I can try reproduce it on my side?
