Hello Damien3,
her it is:
Audirvana Mac Version 3.5.33 (3563)
macOS 10.14.6 with 4096MB RAM
Registriert nach Manuela Paschelke
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Mar 30 19:55:55 2020
Library database path: /Users/manuelapaschelke/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi
HRA-Streaming: Login failed
Max. memory for audio buffers: 1024MB
SHD
Model UID:SHD:2752:0045
UID:AppleUSBAudioEngine:miniDSP:SHD:14200000:1,2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x38 SHD Manufacturer:miniDSP
Model UID:SHD:2752:0045 UID:AppleUSBAudioEngine:miniDSP:SHD:14200000:1,2
Stream ID 0x39 2 channels starting at 1
18 virtual formats:
24 physical formats
Device #0: ID 0x2e Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:114 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x38 SHD Manufacturer: miniDSP Model UID: SHD:2752:0045 UID: AppleUSBAudioEngine:miniDSP:SHD:14200000:1,2
