Hi Folks, this is my first post on the forum. I’ve purchased Audrivana Origin and am very happy with it, especially since I purchased a Topping D50s DAC. I would like to also install an Apple EQ plugin but I’m not sure if Origin offers one. I’ve gone into Audio prefs but I can’t see anything there. Can anyone help on where it is and how I install it? Cheers …
I believe this is the same as in Audirvana Studio… In the “Settings” window under “Audio Units”, click on the little “gear” icon it will pop-open the Audio Units plug-ins inserts window… Your Audio Units plug-in should be available.
Hello @Shuddersfield,
You do not have to install AppleEQ as they are already in MacOS and available in Audirvāna Origin settings under the processing section
Thats exactly right, thanks so much
Perfect, thanks very much
You can add any others you may want there, free or paid EQ…
