EQ Plugin for more than 10 bands
Hello experts,
Is there any EQ Plugin so as to use as I need to add more than 10 bands that offered from standard dsp of Audirvana.
I try ZL Equalizer 2 but is too buggy and can not save more than 1 preset.
I was looking something like Peace, is there any? As I see there is not option like Opra of Roon that gives the option to change and taste different profiles
Thanks in advance
What is the reason for more EQ bands? What is your goal in applying EQ?
A general internet search for ‘Audio Plug-ins’ will provide you with a myriad of results… Otherwise, you need to be more specific about your application of EQ, as there are many approaches and products that may serve those goals most specifically…
If you are wanting to use more than 10 bands of EQ for Room Correction I would suggest a Convolution+FIR filter solution… If you are using EQ for Tone and/or Color you might look at some Old Skool Mastering EQs like the Massive Passive or GML 8200 emulations…
As @Agoldnear suggests above… More information about your kit and use case would help us provide you with more precise suggestions…
