Hello, I want to erase the albuns of Bjork. I have already throw them alway from my “bibliotheque” and they are not at the “documents” anymore. They are not on my computer, but they keep showing Bjork on Aldirvana. What to do?
Hello Ironz, thanks for answering. No, I erased them from my Mac.
Rebuild database in settings maybe?
I’ll try.
Not yet.
Sync
shall i reinstall the app?
No. Flip on your resync folders at startup, shut down your computer and restart. Let’s see before you do that
I’ve just deleted the “recently added” and it’s gone!
You can delete the library restart everything and re add it as well
Thank you
Bork doesn’t go down easily
AHAHAHAHAH aahah
