Erreur au démarrage de la lecture audio
Bonjour,
Ce message s’affiche dĂšs que je lis une source, n’importe laquelle. Comment rĂ©gler ce sujet rapidement? Merci
Have you tried restarting Audirvana? Reduce pre-load cache.
Could you paste the debug info here?
I dont know how to reduce pre load cache. I m not a geek at all. Here s the debuf info
Thank you
From the Audirvana menu, select “Debug info”. It will be copied to the clipboard and you just need to paste it here.
