Bonjour,
Ce message d’erreur s’affiche dès que je veux lire une piste… Merci de m’apporter une solution.
Cordialement,
Alexandre
Audirvana Studio 2.8.1 (20801)
macOS 14.4.1 with 8GB physical RAM
Connected account of : Alexandre DUMONT
r8brain to DSD256 with filter type B 7th order
Sync list: 5 folders
AUTO: /Users/lydiedescourvieres/Downloads
AUTO: /Users/lydiedescourvieres/Downloads/90415-813543020271-jazz-at-the-pawnshop-late-night-stereo128
AUTO: /Users/lydiedescourvieres/Downloads/90747-2XHDJA1148-keep-it-simple-stereo128
AUTO: /Users/lydiedescourvieres/Music/HDtracks/Duke Ellington
AUTO: /Users/lydiedescourvieres/Music/HDtracks/Michael Jackson
iTunes/Music library synchronization: last synchronized on Sat Dec 2 15:16:39 2023
Library database path: /Users/lydiedescourvieres/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 220
Listening on 127.0.0.1 on port 50559
UI theme: light
Font size: large
Language: Langue du système
Ma Musique
Radios
Podcasts
Streaming
Startup view: Ma Musique : Albums
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Max. memory for audio buffers: 2002MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
MICROMEGA MICROMEGA M-One Audio 2.0
Model UID:MICROMEGA M-One Audio 2.0:26F2:0400
UID:AppleUSBAudioEngine:MICROMEGA:MICROMEGA M-One Audio 2.0:14600000:1
Active Sample Rate: 48kHz
Selected device:MICROMEGA M-One Audio 2.0
Manufacturer: MICROMEGA
Model name: MICROMEGA M-One Audio 2.0
Model UID: MICROMEGA M-One Audio 2.0:26F2:0400
UID: AppleUSBAudioEngine:MICROMEGA:MICROMEGA M-One Audio 2.0:14600000:1
USB Vendor ID: 0x26f2
USB Product ID: 0x0400
ID 0x55
Max volume alert: Disabled
DSD via PCM 1.0
Stream ID 0x56 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x6c Philips FTV
Model UID: AppleGFXHDA:0
UID: AppleGFXHDAEngineOutputDP:f803:0:{0C41-01EA-01010101}
Model name: Apple Inc. Philips FTV
Device #1: ID 0x55 MICROMEGA M-One Audio 2.0
Device #2: ID 0x66 Haut-parleurs Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs Mac mini
UPnP devices found : 1
Device #0: ID 0x0 : Cuisine
UID: uuid:9ab0c000-f668-11de-9976-64cc22e60858
Location: http://192.168.1.11:49154/MediaRenderer/desc.xml
Manufacturer: Yamaha Corporation
Model name: WX-021
